Object Reference : Object Command Summary : S
S
SAIC UI:535
Sample
adjustment in estimation UII:904
@all UI:138, C:493
all observations UI:138, C:493
attribute setting O:581
balanced UII:1863
breaks UI:664
change UI:137
change using for loop C:147
command UI:139
common UI:195
current UI:49
data members O:576
date pairs UI:137
@day C:493
declare O:580
display sample specification in O:582
earliest of first panel obs C:493
earliest of last panel obs C:493
@first UI:138, C:493
first observation UI:138, C:493
@hour C:493
@hourf C:493
if condition UI:138
individual UI:195
intraday data UI:140
@last C:493
last observation UI:138, C:493
latest of first panel obs C:493
latest of last panel obs C:493
local C:163
@month C:493
number of observations in C:622
procs O:576
@quarter C:493
range pairs UI:137
retrieve current default C:622
selection and missing values UI:139
set current C:492
set sample specification in O:581
specifying sample object UI:145
specifying samples in panel workfiles UII:1900
used in estimation UII:903
using sample objects in expressions UI:145
views O:576
@weekday C:493
with expressions UI:140
workfile UI:136
@year C:493
sample O:580
Samples
local C:163
sar C:638
SAR specification UII:997, UII:1000, C:638
SAR(p)
estimation UII:1007
SARMA UII:997, C:638
SAS file UI:36, C:530
Save C:546
backup workfile UI:64
commands in file C:5
graphs UI:825
objects to disk C:31
options UI:323
save as new workfile UI:64
spool UI:858
tables UI:837, C:66
workfile UI:63, C:546
workfile as foreign file UI:161, C:546
workfile precision and compression UI:65
save C:484, 0:259, O:312, O:858, O:885
saveprgini C:776
Scalar UI:209, O:583
attribute setting O:586
data members O:583
declare O:586
matrix equal to C:264
procs O:583
spreadsheet view O:587
views O:583
scalar O:586
@scale C:741
scale O:314
Scale factor UII:1258
Scale rows or columns of matrix C:741
Scaled coefficients UII:1070, O:67
Scaling
factor analysis UII:2049
scat O:1035
scatmat O:1039
scatpair O:1042
Scatterplot UI:715, O:1035
categorical UI:767
matrix of UI:676, O:1039
pairs graph O:1042
with confidence ellipse UI:751
with kernel fit O:370
with kernel regression fit UI:745
with nearest neighbor fit UI:747, O:377
with orthogonal regression line UI:750
with regression line UI:742
with regression line fit O:371
scenario O:498
Scenarios UII:1795, O:498
simple example UII:1243
scenlist O:500
Schwarz criterion UII:2147
equation data member O:39
for equation UII:909
pool data member O:512
system data member O:807
VAR data member O:907
Score coefficients UII:2052
Score vector UII:1242
Scores UII:2051
scores O:217, O:239
Scree plot O:203
SDMX data UI:407
SDMX_ML format C:349
@seas C:624
seas C:485, O:642
Seasonal
ARMA terms UII:997, C:638, C:639
difference UI:193, UII:1009
dummy variable C:624
graphs UI:721, O:1046
Seasonal adjustment UI:472
additive UI:523
Census X-11 (historical) UI:518
Census X-12 UI:509
Census X-13 UI:472, O:690
movereg O:633
MoveReg decomposition UI:500
moving average C:485, O:642
multiplicative UI:523
STL O:668
STL decomposition UI:491
Tramo/Seats UI:518, O:672
weekly UI:500
X-11 O:683
X-12 O:685
Seasonal unit root test UII:1547, O:643
Seasonal unit roots UII:1547
seasplot O:1046
seasuroot O:643
@second C:113, C:624
Second derivative methods UII:2131
Second moment matrix C:724
Seed random number generator C:479
Seemingly unrelated regression UII:1591, UII:1620
Seemingly unrelated regression See SUR.
Select
all UI:106
object UI:105
Selection model
Heckman selection equation C:385, O:118
Selection model See Heckman selection
Sensitivity of binary prediction UII:1237
@seq C:742
Seqiuence
arithmetic C:742
multiplicative C:742
@seqm C:742
Sequential breakpoint
estimation with 1:1338
tests UII:1106, O:148
Sequential LR tests C:153
Serial correlation
ARIMA models UII:998
Breusch-Godfrey LM test C:302, O:51
Durbin-Watson statistic UII:908, UII:1001
first order UII:994
higher order UII:995
multivariate VAR LM test O:911
nonlinear models UII:1033
switching models 1:1441
theory UII:993
two stage regression UII:1033
Serial correlation test
equations UII:1001, UII:1089
panels UII:1962, O:42
VARs UII:1648
Series UI:425, O:589
adjust values UI:461, O:593
alpha formula O:10
attribute setting O:647
auto-series UI:201
auto-updating UI:211, C:369, O:622
auto-updating and databases UI:215
auto-updating and forecasting UII:1061
bin recoding O:605
binning UI:463
categorize O:605
classification UI:463
comparison UI:461
convert to matrix C:271, C:730
convert to matrix (keep NAs) C:746
create UI:124, UI:197
cross-section specific UII:1845
data members O:591
declare O:645
delete observation UI:132
description of UI:123
descriptive statistics UI:426, C:497, O:668
difference UI:192
display format UI:125
display type UI:125
duplicate observations O:9, O:611
dynamic assignment UI:199
edit in differences UI:577
edit mode default UI:2098
editing UI:131, 1:2115
element function O:592
extract observation C:621
fill (background) color for cells O:649
fill values UI:461, O:593, O:617
formula C:369, O:622
frequency conversion default method O:647
functions UI:189
generate by command UI:200
graph UI:426, UI:659
graph views O:590
implicit assignment UI:199
in pool objects UII:1846
indentation O:656
initialize O:617
insert observation UI:132
interpolate UI:469, O:626
lag UI:191
lead UI:191
pooled UII:1846
preview C:469
previewing contents UI:107
procs UI:462, O:590
properties UI:460
ranking UI:194
resample UI:467
setting graph axis UI:690
smoothing C:490, O:663
smpl+/- UI:128
sort O:665
spreadsheet view UI:426
spreadsheet view defaults UI:2097
text color for cells O:657
unique values C:752
using expressions in place of UI:201
value maps O:633
views O:589
series O:645
@seriesname UI:207, O:333
S-estimation 1:1322, O:170
performing in EViews 1:1325
tuning constants 1:1323
weight function 1:1322
set O:581
SETAR UI:1357, O:181
setattr O:14, O:27, O:171, O:238, 0:261, O:314, O:383, O:415, O:430, O:462, O:500, O:541, O:570, O:581, O:586, O:647, O:721, O:750, O:763, O:769, O:797, O:837, O:860, O:886, 0:894, O:901, O:954, O:984
setbpelem O:315
setcell C:486
setcollabels O:462
setcolwidth C:487
setconvert O:647
setelem O:316
seterrcount C:777
setfillcolor 0:262, O:383, O:649, O:861
setfont 0:268, O:320, O:722, O:863
setformat O:27, O:388, O:463, O:570, O:653, O:797, O:864, O:984
setglobalc O:985
setheight O:868
setindent O:15, O:28, O:391, O:464, O:571, O:656, O:798, O:869, O:986
setjust O:15, O:29, O:392, O:464, O:572, O:657, O:799, O:869, O:986
setline C:488
setlines O:870
setmaxerrs C:778
setmerge O:872
setobslabel O:321
setrowlabels O:465
settextcolor O:393, O:657, O:874
setupdate O:323
setwidth O:29, O:397, O:466, O:573, O:662, O:800, O:875, O:987
Shade region of graph UI:796, O:293
by command C:51
Shadowing of object names UI:350
Shape
background color 0:262
Shapefile
link to series 0:255
load from disk 0:256
Sharing violation UI:328
sheet
alpha O:16
coef O:30
group O:398
matrix O:466
pool O:542
rowvector O:573
scalar O:587
series O:662
svector O:770
sym O:800
table O:876
valmap O:902
vector O:988
Shell C:489
shell C:489
show C:489
Show object view UI:106, C:489
Siddiqui difference quotient UII:1473, UII:1486
Siegel-Tukey test UI:440, O:670
Sign
matrix element by element C:743
@sign C:743
Sign test UI:434, O:671
Signal equation UII:1759
Signal variables
display graphs O:750
saving O:743
views UII:1772
signalgraph O:750
Silverman bandwidth UI:731
Simple switching
regime probabilities UI:1726
Sims-Zha prior O:913
Simultaneous equations See systems.
@sin C:592, C:618
Sine C:592, C:618
Singular matrix
error in binary estimation UII:1235
error in estimation UII:916, UII:953, UII:2129
error in logl UII:1499, UII:1507, UII:1509
error in PDL estimation UII:918
error in RESET test UII:1119
test for C:726
Singular value decomposition C:747, C:748
@skew C:577, C:619
Skewness UI:427, C:577, C:619
by category C:588, C:619
moving C:583, C:585, C:613, C:614
@skewsby C:588, C:619
sleep C:778
@slope C:743
Slope equality test O:159
Slope equality test (quantile regression) UII:1480
technical details UII:1492
sma C:639
SMA specification UII:997, UII:1000
smooth C:490, O:663
Smooth threshold autoregression UII:1373, O:181
Smooth transition regression
transition functions UII:1374
Smoothed AIC weights UI:535
Smoothing
ETS model UI:545, O:614
exponential smooth series C:490, O:663
likelihood based UI:545, O:614
Markov switching 1:1439, UI:1730
methods UI:539
parameters UI:540
signal series O:743
state series O:744
state space UII:1755
smpl C:492
Smpl command UI:139
Smpl+/- UI:128
Snapshots
defaults UI:2093
Solve
Broyden UII:1828
Gauss-Seidel UII:2134
linear system C:743
Newton-Raphson UII:2131
See also Models.
simultaneous equations model C:494, O:502
solve C:494, O:502
solveopt O:503
@solvesystem C:743
Sort O:17, O:324, O:399, O:665
display UI:579
observations in a graph UI:663, UI:804
spreadsheet display UI:579
table rows O:876
valmaps UI:231
vector C:744
workfile UI:323
workfile page C:495
@sort C:744
sort C:495, O:17, O:324, O:399, O:665, O:876
Source
field in database query UI:347
Sparse label option UI:430, UI:614
spawn C:496
Spawn process within EViews C:496
Spearman covariance
panel data O:635
Spearman rank correlation UI:600
from group O:344
from matrix O:438
from sym O:776
from vector O:970
Spearman rank covariance
from group O:348
from matrix O:441
from sym O:779
Spearman rank-order
theory UI:609
spec O:431, O:504, O:582, O:751, O:838
Special functions C:589
Specification
by formula UII:901
by list UII:900
of equation UII:900, O:164
of nonlinear equation UII:947
of pool O:539
of system O:835
of systems UII:1594
of VAR O:950
Specification test
for binary models UII:1245
for overdispersion UII:1279
for tobit UII:1261
of equation UII:1069
RESET (Ramsey) UII:1118
White UII:1093
Specification view
logl O:431
model O:504
sspace O:751
system O:838
Specificity of binary prediction UII:1237
Spectrum estimation UII:1528, UII:1529
spike O:1047
Spike graph UI:711, O:1047
Spool UI:839, O:704
add objects C:70
add objects by command C:70
add to UI:840
add/append objects O:706
appending UI:841
attribute setting O:721
comment setting O:722
comments UI:844, O:707
comments by command C:73
copying to UI:841
create UI:839
create by command C:69
customization UI:851
data members O:705
declare spool object O:723
delete objects UI:848
display contents O:708
display mode UI:853, O:710, O:723
display name C:72
display name by command C:72
embedding UI:842
extract UI:848, O:709
extract by command C:73
flatten tree hierarchy UI:849, O:710
font setting O:722
graph display mode O:710
hide objects O:711
hiding objects UI:845
horizontal indentation O:711
indentation UI:848
insert object O:712
left margin O:715
management UI:840
move object O:716
name object O:717
naming objects UI:844
naming objects by command C:72
object comments C:73
object names C:72
options O:718
order UI:848
print UI:2111
print by command C:74
print object O:719
print size UI:858
print to UI:840
printing UI:857
procs O:704
properties UI:851
rearrange UI:848
redirecting print to UI:2111
remove object O:719
removing objects C:73
resize UI:847
saving UI:858, O:720
show objects in spool O:723
table and text display mode O:723
title O:724
top margin O:725
vertical indentation O:725
vertical spacing O:726
views O:704
widths O:727
Spreadsheet
file export C:546
file import UI:150, C:390, C:530
file import as matrix UI:161, C:400, O:446, O:560, O:787, O:975
file import as table UI:161, UI:838, C:407
series UI:426
sort display default UI:2098
sort display order UI:579, O:17, O:399, O:665
view option UI:2097, UI:2098
Spreadsheet view
alpha UI:223, O:16
coef O:30
display type UI:125
group UI:576, O:398
matrix O:466
pool O:542
rowvector O:573
scalar O:587
series O:662
svector O:770
sym O:800
table O:876
valmap O:902
vector O:988
SPSS file UI:36, C:530
@sqrt C:570, C:619
sqrt C:570, C:619
Square root C:570, C:619
Squared multiple correlation O:242
SSAR 1:1443
SSCP UI:602
Sspace O:729
append specification line O:733
attribute setting O:750
coefficient covariance O:735
data members O:730
declare O:752
display signal graphs O:750
make Kalman filter from O:741
method O:729
procs O:729
specification display O:755
state graphs O:753
views O:729
sspace O:752
Stability test UII:1099
Bai Perron tests UII:1104, O:148
Chow breakpoint UII:1100, C:313, O:63
Chow forecast UII:1116
factor C:358, O:92
Quandt-Andrews O:191
RESET UII:1118
smooth transition UII:1390
unknown breakpoint O:191
with unequal variance UII:1128
Stack
matrix by column C:755
sym matrix by lower column triangle C:755
workfile page C:460
Stacked data UII:1849
balanced UII:1852
descriptive statistics UII:1857
order UII:1851
Stacking data UI:315
Standard deviation UI:427, C:577, C:584, C:614, C:619
cumulative C:579, C:580, C:607
matrix columns C:707
moving C:582, C:584, C:613, C:614
row-wise C:586, C:618
Standard error
for estimated coefficient UII:906
forecast UII:1050, UII:1064
of the regression UII:908
retrieve from equation O:39
retrieve from system O:806
retrieve from VAR O:906
See also Robust standard errors.
VAR UII:1652
Standard errors
cluster-robust UI:52, UII:933
Standardize C:577, C:619, C:702, C:744
population C:577, C:619, C:745
matrix columns C:703
Standardized coefficients UII:1070, O:67
Standardized residual UII:912
binary models UII:1241
censored models UII:1259
count models UII:1278
GLM UII:1301
truncated models UII:1264
STAR UII:1373, O:181
Start
field in database query UI:346
field in workfile details UI:52
Start page UI:2089
Starting values C:468
(G)ARCH models UII:1143
binary models UII:1234
for ARMA estimation UII:1012, UII:1018
for coefficients UII:951, UII:2127
for nonlinear least squares UII:948, UII:950
for systems UII:1598
logl UII:1503
param statement UII:951, UII:2128
state space UII:1763
user defined optimization 1:246
user supplied UII:1013, UII:1018
Stata file UI:36, C:530
statby O:666
State equation UII:1754, UII:1758
State space UII:1753
estimation UII:1757, UII:1768
filtering UII:1754
forecasting UII:1756
interpreting UII:1769
@mprior UII:1763
observation equation UII:1754
representation UII:1753
specification UII:1753, UII:1758, O:755
specification (automatic) UII:1766
starting values UII:1763
state equation UII:1754
views UII:1771
@vprior UII:1763
State variables UII:1753
display graphs of O:753
final one-step ahead predictions O:752
initial values O:754
smoothed series O:744
State views UII:1772
statefinal O:752
stategraphs O:753
stateinit O:754
Static forecast UII:1055, C:364, O:93
Static OLS UII:1162, UII:1163
Stationary time series UII:1519
Statistical distribution functions C:592
Statistics
compute for subgroups O:666
pool O:520
stats
coef O:30
group O:400
matrix O:467
rowvector O:574
series C:497, O:668
sym O:801
valmap O:902
Status line UI:93, C:498
statusline C:498, C:778
@stdev C:577, C:619
@stdevp C:577
@stdevpsby C:588, C:619
@stdevs C:577, C:619
@stdevsby C:588, C:619
@stdevssby C:588, C:619
@stdize C:577, C:619, C:744
@stdizep C:577, C:619, C:745
step C:779
Step size UII:2133
logl UII:1501
Step weights II:1211
stepls C:499, O:172
Stepwise UII:954, C:499, O:172
swapwise UII:959
uni-directional UII:958
STL O:668
stl O:668
stochastic O:505
Stochastic equations
in model UII:1780
stom C:745
stomna C:746
stop C:780
Stop program execution C:126, C:152, C:780
Store UI:120
as .DB? file UI:331
from pool UII:1860, O:542
in database UI:330
merge objects UI:331
object in database or databank C:31, C:500
store C:500, O:542
@str C:89, C:661
@strdate C:90, C:113, C:624, C:665
String C:77, O:759
add quotes C:87, C:643
as replacement variable C:134
assign to table cell C:58
attribute setting O:763
change case C:87
comparison C:79
concatenation C:78
convert date string to observation C:90, C:91
convert date value into C:650
convert date value to string C:106
convert from a number C:661
convert into date value C:651
convert number to string C:89
convert to date number C:89, C:105
convert to number C:90, C:133, C:671
convert to numbers C:82
current date as a string C:91
data members O:759
declare O:764
display list view O:762
display view of string O:764
extract portion C:84, C:85
find substring C:83, C:653, C:660
for loop C:149
functions C:82, C:598
in programs C:131
insert string into another string C:85, C:652
left substring C:654
length C:82, C:654, C:667
lowercase C:655
missing value C:77, C:81
null string C:77
operators C:78
ordering C:79
program arguments C:138, C:141, C:143
relational comparison C:79
relational comparisons with empty strings C:81
replace portion of a string with new string C:86, C:659
right substring C:659
string lists C:81
strip commas C:666
strip parentheses from ends C:87, C:666
strip quotes from ends C:87, C:667
substring from location C:657
test for blank C:83, C:653
test for equality C:652
test for inequality C:657
test two strings for equality C:83
test two strings for inequality C:83
trim spaces C:86
trim spaces from ends C:86, C:668
trim spaces from left end C:656
trim spaces from right end C:660
uppercase C:670
variable C:92, C:131
vectors C:93
views O:759
string O:764
string O:764
String (variable) C:92
String list
compare strings C:87, C:679
count C:82, C:673
create from svector C:90, C:677
create svector C:90, C:683
cross lists C:88, C:674
delimiters C:88, C:674
drop string C:86, C:675
extract string C:85, C:678
find element C:85, C:680
find string C:83, C:675, C:676
functions C:642
interleave lists C:88, C:676
intersect strings C:87, C:677
left substring C:84, C:678
replace string C:86, C:682
right substring C:85, C:682
sort C:88, C:683
substring from location C:85, C:679
union of strings C:87, C:683
unique string C:87, C:684
String object C:92, C:133
String series O:4
String vector C:93
row count C:90, C:660
@stripparens C:87, C:666
@strippcommas C:666
@stripquotes C:87, C:667
@strlen C:667
@strnow C:91, C:667
Structural change
See also Breakpoint test.
estimation in the presence of 1:1337, C:305, O:54
tests of UII:1099, UII:1104, O:148
Structural forecast UII:1056
Structural solution of models UII:1821
Structural VAR UII:1658, O:909
estimation UII:1667
factorization matrix UII:1649
structure O:755
Structuring a workfile UI:271, C:463
Studentized residual UII:1125, O:124
@subextract C:747
Subroutine C:155
arguments C:155
call C:157, C:762
declare C:780
define C:155
global C:160
local C:162
mark end C:764
optimization 1:243
placement C:159
return from C:155, C:775
subroutine C:780
Substring C:85, C:653, C:657, C:660, C:679
Subtitle
Breusch-Pagan LM test UII:1958
Friedman test O:164
Pearson CD test O:164
Subtraction operator (-) C:274
Sum C:577, C:619
cumulative C:578, C:580, C:607
moving C:581, C:583, C:614
@sum C:577, C:619
Sum of squared residuals
for regression UII:908
Sum of squares C:577, C:619
cumulative C:579, C:581, C:607
matrix columns C:708
moving C:583, C:585, C:614
row-wise C:587, C:618
Summarizing data UI:582
See Dated data table.
Summary statistics
for regression variables UII:907
@sumsby C:588, C:619
@sumsq C:577, C:619
@sumsqby C:588, C:619
SUR UII:1591, UII:1620
estimating by command O:838
sur O:838
Survivor O:1007
Survivor function UI:735
log UI:735
save data UI:571, O:610
svar O:954
@svd C:747, C:748
Svector O:766
attribute setting O:769
create from string list C:90
create string list C:90, C:677
data members O:766
declare O:770
make from text object O:886
spreadsheet view O:770
views O:766
svector O:770
Swapwise UII:959
@sweep C:749
Sweep operator C:749
reverse C:740
Switching regression 1:1435, C:502, O:175
dynamic models 1:1440, O:176
estimation in EViews 1:1443
expected durations 1:1451, UI:1737, O:143, O:176, O:185, O:957, O:961
filtering 1:1437
initial probabilities 1:1446, UI:1733
regime probabilities 1:1436, 1:1453, 1:1454, UI:1738, UI:1740, O:142, O:166
serial correlation 1:1441
transition probabilities 1:1451, UI:1737, O:143, O:176, O:185, O:957, O:961
transition results 1:1451, 1:1454, UI:1737, UI:1739, O:143, O:176, O:185, O:957, O:961
views available 1:1451, UI:1736
Switching VAR UI:1723, O:956
transition probabilities O:945
expected durations O:945
regime probabilities O:943, O:953
transition results O:945
SwitchingVAR
switching intercept likelihood UI:1725
switchreg C:502, O:175
Sym O:773
attribute setting O:797
create from lower triangle of square matrix C:724
create from scalar function C:721
create square matrix from C:719
data members O:774
declare O:801
descriptive statistics O:801
graph views O:773
indentation O:798
initialize O:786
procs O:774
scale rows and columns C:741
spreadsheet view O:800
stack columns C:755
views O:773
sym O:801
Symbol graph UI:707
Symmetric matrix
See Sym.
Symmetric quantiles test UII:1481
technical details UII:1493
Symmetrically trimmed residuals UII:1261
Symmetry test O:161
Syntax coloring UI:2102
System UII:1589, O:805
3SLS O:808
append specification line O:809
ARCH UII:1592
attribute setting O:837
coefficient covariance O:817
covariance matrix UII:1605
create UII:1592, UII:1593
create from group O:375
create from pool O:533
create from var O:945
cross-equation weighting UII:1590
data members O:806
declare O:839
definition UII:1589
derivatives UII:1605, O:818
display gradients O:826
estimation UII:1590, UII:1598
estimation covariance O:821
estimation methods (technical) UII:1618
FIML UII:1622
FIML estimation O:822
forecast UII:1606
full information maximum likelihood UII:1592
GMM UII:1623
gradients UII:1605
Instruments UII:1595
make system from group UI:640
methods O:805
OLS UII:1590, UII:1619
options UII:1602
procs O:806
residuals UII:1607
specification UII:1594
specify O:814
specify from VAR UII:1657
three stage least squares UII:1591, UII:1622
two stage least squares UII:1591, UII:1621
views UII:1605, O:805
weighted least squares UII:1591, UII:1619, O:842
system O:839
System options UI:2107
