Object Reference : Object View and Procedure Reference : Matrix
cov
Compute covariances, correlations, and other measures of association for the columns in a matrix.
You may compute measures related to Pearson product-moment (ordinary) covariances and correlations, Spearman rank covariances, or Kendall’s tau along with test statistics for evaluating whether the correlations are equal to zero.
matrix_name.cov(options) [keywords [@partial z1 z2 z3...]]
You should specify keywords indicating the statistics you wish to display from the list below, optionally followed by the keyword @partial and the name of a conditioning matrix. The columns should contain the conditioning variables, and the number of rows should match the original matrix.
You may specify keywords from one of the four sets (Pearson correlation, Spearman correlation, Kendall’s tau, Uncentered Pearson) corresponding the computational method you wish to employ. (You may not select keywords from more than one set.)
If you do not specify keywords, EViews will assume “cov” and compute the Pearson covariance matrix. Note that Matrix::cov is equivalent to the Matrix::cor command with a different default setting.
Pearson Correlation
cov
Product moment covariance.
corr
Product moment correlation.
sscp
Sums-of-squared cross-products.
stat
Test statistic (t-statistic) for evaluating whether the correlation is zero.
prob
Probability under the null for the test statistic.
cases
Number of cases.
obs
Number of observations.
wgts
Sum of the weights.
Spearman Rank Correlation
rcov
Spearman’s rank covariance.
rcorr
Spearman’s rank correlation.
rsscp
rstat
rprob
cases
Number of cases.
obs
wgts
Sum of the weights.
Kendall’s tau
taub
Kendall’s tau-b.
taua
Kendall’s tau-a.
taucd
Kendall’s concordances and discordances.
taustat
Kendall’s score statistic for evaluating whether the Kendall’s tau-b measure is zero.
tauprob
Probability under the null for the score statistic.
cases
Number of cases.
obs
wgts
Sum of the weights.
Uncentered Pearson
ucov
ucorr
usscp
ustat
uprob
cases
Number of cases.
obs
wgts
Sum of the weights.
Note that cases, obs, and wgts are available for each of the methods.
wgt=name (optional)
Name of vector containing weights. The number of rows of the weight vector should match the number of rows in the original matrix.
wgtmethod=arg (default = “sstdev”)
Weighting method (when weights are specified using “weight=”): frequency (“freq”), inverse of variances (“var”), inverse of standard deviation (“stdev”), scaled inverse of variances (“svar”), scaled inverse of standard deviations (“sstdev”).
Only applicable for ordinary (Pearson) calculations. Weights specified by “wgt=” are frequency weights for rank correlation and Kendall’s tau calculations.
pairwise
Compute using pairwise deletion of observations with missing cases (pairwise samples).
df
Compute covariances with a degree-of-freedom correction for the mean (for centered specifications), and any partial conditioning variables.
multi=arg (default=“none”)
Adjustment to p-values for multiple comparisons: none (“none”), Bonferroni (“bonferroni”), Dunn-Sidak (“dunn”).
outfmt=arg (default= “single”)
Output format: single table (“single”), multiple table (“mult”), list (“list”), spreadsheet (“sheet”). Note that “outfmt=sheet” is only applicable if you specify a single statistic keyword.
out=name
Basename for saving output. All results will be saved in Sym matrices named using keys (“COV”, “CORR”, “SSCP”, “TAUA”, “TAUB”, “CONC” (Kendall’s concurrences), “DISC” (Kendall’s discordances), “CASES”, “OBS”, “WGTS”) appended to the basename (e.g., the covariance specified by “out=my” is saved in the Sym matrix “MYCOV”).
prompt
p
Print the result.
mat1.cov
displays a Pearson covariance matrix for the columns series in MAT1.
mat1.cov corr stat prob
displays a table containing the Pearson covariance, t-statistic for testing for zero correlation, and associated p-value, for the columns in MAT1.
mat1.cov(pairwise) taub taustat tauprob
computes the Kendall’s tau-b, score statistic, and p-value for the score statistic, using samples with pairwise missing value exclusion.
mat1.cov(out=aa) cov
computes the Pearson covariance for the columns in MAT1 and saves the results in the symmetric matrix object AACO.
