Object Reference : Object View and Procedure Reference : Matrix
fill
Fill a matrix object with specified values.
matrix_name.fill(options) n1[, n2, n3 …]
Follow the keyword with a list of values to place in the matrix object. Each value should be separated by a comma.
Running out of values before the object is completely filled is not an error; the remaining cells or observations will be unaffected, unless the “l” option is specified. If, however, you list more values than the object can hold, EViews will not modify any observations and will return an error message.
l
Loop repeatedly over the list of values as many times as it takes to fill the object.
o=integer (default=1)
Fill the object starting from the specified element. Default is the first element.
b=arg (default=“c”)
Matrix fill order: “c” (fill the matrix by column), “r” (fill the matrix by row).
The commands,
matrix(2,2) m1
matrix(2,2) m2
m1.fill 1, 0, 1, 2
m2.fill(b=r) 1, 0, 1, 2
create the matrices:
(1.2)
See “Matrix Language” for a detailed discussion of vector and matrix manipulation in EViews.
