Object Reference : Object View and Procedure Reference : Sample
Sample
clearhist
displayname
label
olepush
sample
set
setattr
spec
Sample of observations. Description of a set of observations to be used in operations.
Sample Declaration
sample declare a sample object.
To declare a sample object, use the keyword sample, followed by a name and a sample string:
sample mysample 1960:1 1990:4
sample altsample 120 170 300 1000 if x>0
Sample Views
label label information for the sample.
spec display sample specification information.
Sample Procs
displayname set display name.
olepush push updates to OLE linked objects in open applications .
set reset the sample range.
setattr set the value of an object attribute .
Sample Data Members
String values
@attr(“arg”) string containing the value of the arg attribute, where the argument is specified as a quoted string.
@description string containing the Sample object’s description (if available).
@detailedtype string with the object type: “SAMPLE”.
@displayname string containing the Sample object’s display name. If the Sample has no display name set, the name is returned.
@name string containing the Sample object’s name.
@remarks string containing the Sample object’s remarks (if available).
@source string containing the Sample object’s source (if available).
@type string with the object type: “SAMPLE”.
@updatetime string representation of the time and date at which the Sample was last updated.
Sample Example
To change the observations in a sample object, you can use the set proc:
mysample.set 1960:1 1980:4 if y>0
sample thesamp 1 10 20 30 40 60 if x>0
thesamp.set @all
To set the current sample to use a sample, enter a smpl statement, followed by the name of the sample object:
smpl mysample
equation eq1.ls y x c
