Object Reference : Object View and Procedure Reference : Vector
setjust
Set the display justification for cells in a vector spreadsheet view.
vector_name.setjust format_arg
where format_arg is a set of arguments used to specify format settings. You should enclose the format_arg in double quotes if it contains any spaces or delimiters.
The format_arg may be formed using the following:
top / middle / bottom]
Vertical justification setting.
auto / left / center / right
Horizontal justification setting. “Auto” uses left justification for strings, and right for numbers.
You may enter one or both of the justification settings. The default justification settings are taken from the Global Defaults for spreadsheet views (“Spreadsheet Data Display”) at the time the spreadsheet was created.
v1.setjust middle
sets the vertical justification to the middle.
v1.setjust top left
sets the vertical justification to top and the horizontal justification to left.
See Vector::setwidth and Vector::setindent for details on setting spreadsheet widths and indentation.
