T
add comment to cell
O:849assigning numbers to cells
C:58assigning strings to cells
C:58assignment with formatting
C:59convert from matrix
C:751copy range of cells
O:850copy table to new table
C:505copy to other windows programs
UI:836create using freeze
C:368creating by freezing a view
C:57delete cells from a table
O:852fill (background) color for cells
O:861insert cells into a table
O:855insert table in new table
C:505paste as unformatted text
UI:837read data from foreign source
UI:838set and format cell contents
C:486Tabs
Tabulation
t-distribution function
random number generator
C:618Template
Test
See also Hypothesis tests, Specification test and Goodness of fit
for equality of matrix values
C:713for inequality of matrix values
C:718for serial correlation in VAR
O:911heteroskedasticity in VAR
O:964Johansen cointegration from a VAR
O:917lag exclusion (Wald)
O:960mean, median, variance equality
O:401mean, median, variance equality by classification
O:670Park added variable test
O:67redundant fixed effects
O:95simple mean, median, variance hypotheses
O:671unit root (seasonal)
O:643Text file
Text object
Theoretical distribution graph
UI:733Thresold regression
O:181Time
Trace
TRAMO/SEATS
Transition results
intercept from trend regression
C:575Trigonometric functions
C:592Mean
tsls
t-statistics
retrieve from system
O:807Tukey-Hamming kernel
panel cointegrating regression
1:1977Tukey-Hanning kernel
1:1977Tukey-Parzen kernel
1:1977Tuning constants
Two-stage least squares
See 2sls (Two-Stage Least Squares).
Type
field in database query
UI:345
